Truck will not start with key. Had to put in a push button start. Brake lights stay on until I push the brake then they go off. Air conditioner stopped working. All the panel lights are not working. Already changed out ignition switch and harness. Checked everything I could think of as far as ground wires and relays.
As soon as you turn the key and everything turns on brake lights will not work. When truck is running and hit the brakes they will not turn on and the hazards will not work either.
All this happened after we had a really bad thunderstorm.
Apr 28, 2018 at 12:23 PM
