Electric fault light on
2013 FORD CAPRI
45,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
BRAD COX
Pulled high voltage disconnect behind rear seat to work on vehicle. reinserted electric fault light on will not let car start.
Aug 27, 2019 at 10:08 AM
BMDOUBLE
  • 1,139 POSTS
I attached a picture of a c-max battery disconnect. If yours is like this one, they are very very very finicky and must be installed correctly or you'll have the very symptom you're experiencing.
Aug 28, 2019 at 1:41 AM
