Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Lancer
General
electric dos not stop automatically
2006 MITSUBISHI LANCER
163,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
JUNIOR1964
MEMBER
After turn off the ignition, both fan keep runing, could you please what wrong should be
Jan 20, 2016 at 4:08 AM
HMAC300
Experienced Mechanic
check your relay that operates the cooling fan may be stuck try a like relay and If it continues it may be the fan module.
Jan 20, 2016 at 4:15 AM
WRENCHTECH
Which fans? The inside blower or outside cooling fan?
Jan 20, 2016 at 4:27 AM
WRENCHTECH
Sorry HMAC, got side tracked in the middle of my post.
JUNIOR1964
MEMBER
Is there a fan module where it is located
Jan 20, 2016 at 4:31 AM
HMAC300
left front of engine compartment.
Jan 20, 2016 at 4:51 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
