Electric door locks
198,000 MILES • 3.8L • V8 • 4WD • AUTOMATIC
DRSCHULZ
The drivers side door lock switch will lock the doors but won't unlock them. I have replaced the door and window switch unit in the door arm rest with a new one but the problem is still there. The passenger door switch WILL lock and unlock both doors successfully. Do you have a solution? Thanks Don S.
Feb 9, 2016 at 6:39 AM
HMAC300
  • 48,601 POSTS
it's probably the door lock in the offending door you can check the integration relayin drivers side fuse box. it can also be the unlock switch is bad but it may be part of door lock
Feb 9, 2016 at 7:03 AM
