High beams turn signals wipers went out?
120,200 MILES • 3.6L • V6 • 2WD • AUTOMATIC
KAIDEN WHITE
Hi beams turn signals and wipers all went out after hooking a amp to the rear fuse box
Dec 31, 2025 at 12:37 PM
STEVE W.
  • 15,399 POSTS
What terminal or fuse did you connect the amp to in the rear box? Can you still start the car and does the horn work? Asking because those use the main power feed to the rear fuse box as the lights and wipers. That vehicle has multiple power feeds that are controlled from the front control module and the FCM in turn is controlled by other feeds. Knowing where you connected would save time in tracing if it's a fuse or if it damaged the CCM or the actual fuse box was damaged.
Dec 31, 2025 at 8:23 PM
  • 55,676 POSTS
Yep, I agree with Steve W., also please check all fuses with the systems on. This guide can help
Please go over this guide and get back to us.
Jan 1, 2026 at 5:49 AM
