When trying to start vehicle after replacing fuel pump all the lights started blinking and flashing and the horn is blinking on
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
CHRISTOPHER DUNCAN
The truck has been sitting for months because of a bad fuel pump. so I replace the fuel pump and when I turn the key on to start it all the lights are blinking and flashing and the horn is blinking on.
May 22, 2020 at 4:04 AM
Good afternoon,
I would start by charging or changing the battery. This whole issue sounds like low voltage.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Do you have a voltmeter to do tests?
May 22, 2020 at 4:45 AM
