no wipers or blower controls?
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
DNNSB49
Changed the steering coupler and now no wipers or blower controls and all wires seem to be plugged in.
Mar 22, 2023 at 8:03 AM
  • 55,797 POSTS
Steering coupler? Can you please expand on that? So, there is a smart junction box that powers these items I would start by checking for power at the fuses.
Here is a guide that will help:
The fuses you should check are in the images below. If no power is present when the key is on, then the SJB needs to be replaced which I have left instruction for. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Mar 23, 2023 at 2:06 AM
DNNSB49
I got it figured out. the ignition starter switch went bad for some reason when I changed coupler.
Mar 24, 2023 at 2:34 AM
  • 55,797 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Mar 24, 2023 at 2:45 AM
