After replacing battery electricals not working
232,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
  • 98 POSTS
I left the key on for a few hours and drained the battery. I took it down and had it charged. But there is still nothing. No lights ,buzzer or bells. I don't know what to do next. Please help.
Jun 29, 2021 at 3:59 AM
  • 110,248 POSTS
If nothing is working, I need you to locate the fuse/fusible link box under the hood. See pic 1 below for the location.
Next, in pic 2, I highlighted a fusible link that I need to be checked. A fusible link is basically a fuse but is designed differently to do the same thing. Confirm it is good. Also, confirm there is power to and from it.
Also in pic 2, I highlighted and circled the power supply wire to the box. Simply confirm there is 12v present on that wire/bolt. You can use a test light, multimeter, or voltmeter.
Here is a link that shows how to use a test light:
Let me know what you find.
Jun 29, 2021 at 2:49 PM
  • 98 POSTS
I've found the fuse box and the fuse was bad. But I also found corrosion everything from the battery post to the starter.
Jun 30, 2021 at 3:14 AM
  • 110,248 POSTS
Make sure the battery is disconnected and then do your best to clean everything. Once you get the corrosion off the connections, use dielectric grease where the connection is made. That will help produce a good connection and prevent corrosion.
Interestingly, the corrosion may have been the cause of the fuse issue. When there isn't a good connection, there is more heat and energy draw. As crazy as it sounds, that may have done it.
Here is a link that shows how to take care of the battery terminals. You may find it helpful.
Jun 30, 2021 at 2:16 PM
  • 98 POSTS
Cleaned all of corrosion and replaced the fusible link and she started right up.
Thank you very much.
Jul 2, 2021 at 3:18 AM
  • 110,248 POSTS
You are very welcome. I'm glad to hear it's running again for you.
Please feel free to come back in the future if you have any questions. You are always welcome here.
Take care of yourself and Happy 4th!!!
Jul 2, 2021 at 11:47 AM
  • 98 POSTS
Have a happy 4th.
Jul 2, 2021 at 11:49 AM
  • 110,248 POSTS
Thanks. For a change, the weather is to be good. LOL
You as well,
Jul 2, 2021 at 11:52 AM
