Crank no start issue
212,456 MILES • 3.0L • 6 CYL • 2WD
JOHNNY RUSSELL
Replaced crank sensor, cam sensor both and battery. Engine turns over but will not start, not even with ether.
Mar 6, 2022 at 5:38 PM
Good morning,
When you crank the engine, does the tach on the dash show any RPM? If it does, then the crank sensor is sending a signal to the ECM.
https://www.2carpros.com/articles/car-not-running-advanced
You need to check spark and compression to be sure there are no internal motor issues.
Mar 6, 2022 at 6:08 PM
