EGR control solenoid valve code p1400 part 2
99,000 MILES • 6.0L • 6 CYL • FWD • AUTOMATIC
BLUE721
Is there a fuse to the solenoid and where it is and what number is it?
Sep 8, 2016 at 8:34 AM
This does have a fuse. It is fuse 17 in the junction block. I attached the info for this fuse.
However, I also attached the testing that we need to run through to find out what the issue is. This requires the use of a voltage meter and here is a guide that will help with that.
Run through this and let me know what questions you have. Thanks
Nov 27, 2020 at 11:51 PM
