Okay, I attached a flow chart for checks needed for this code. The most common reason for this code is low fuel pressure from a bad fuel pump, but it needs to be confirmed with a fuel pressure test. if you do not have a tester, you can rent one at a parts store.
Images (Click to enlarge)
Mar 4, 2018 at 10:41 PM
