EGR valve delete
198,000 MILES • 3.9L • V6 • 4WD • MANUAL
FORENSICS
  • 112 POSTS
So, I am pretty sure my EYE valve has gone bad since it is the original one that came with the vehicle. When I start my truck it has a terrible cold idle but once it warms up it is almost okay, but if you turn on the A/C or push in the clutch it sounds as if it wants to shut off but does not and then goes back to normal. Along with that the little black plastic vacuum device that connects to it leaks air out the bottom and does not push any air into the EGR. When I saw that I pulled off the black device while it was running and the idle did not change at all still sounded and ran terrible cold. So I am wondering if it is safe to just put a delete cover over it and bypass the check engine light that will come on once removed?
If I cannot bypass the check engine light that will come on once it is removed then I will just save up for another one.
Sep 12, 2018 at 8:32 AM
FORENSICS
  • 112 POSTS
Never mind. I thought I would try unplugging it to check if the engine light would come on and there is none. So now I would just like to know if it is completely safe to put a delete plate over it.
Sep 12, 2018 at 9:02 AM
  • 110,246 POSTS
You should replace the EGR if it is bad. The bottom line, there is a check engine light and it will set if the EGR is removed. The light may not come on right away. However, once the computer goes through test sequences, it will eventually come on. Additionally, removing the EGR will increase the emissions produced by the engine, specifically, nox gases. Removing the EGR will end up setting other codes, too. Also, there could be a code already stored in the system. Here are directions on how to check an OBD1 system:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Check to see if there are codes. Honestly, the EGR does hardly anything at low idle speeds. Very little exhaust gases are recirculated at low engine speeds. If there were higher amounts, the engine would not run. Have you checked for a vacuum leak? Have you checked fuel pump pressure?
Sep 12, 2018 at 11:56 AM
FORENSICS
  • 112 POSTS
I am just trying to fix as many things that could involve the cold idle because when the motor is started cold the idle freaks out going up and down and sometimes almost sounding like it wants to shut off. I do know that at cold idle revving it past around 2,000 rpm it will make this jolting feeling and start having a normal acceleration. However, once it goes back to idle it starts going up and down and sometimes it will freeze at about 1,000 rpm's almost like it is stuttering.
Things I do know:
EGR VALVE is bad
Compression is random between 150 to 180psi in each cylinder (each cylinder sometimes reads 150 or 180).
Fuel is running rich because two of the six new spark plugs were black after only running for fifteen minutes.
Each cylinder is firing I have tested by pulling the plugs on injectors.
Only things I haven't changed is the EGR valve and o2 sensor
I am pretty sure I have solved every vacuum leak on my truck.
Oh and after the idle calms down once the truck warms up if you push on the clutch or turn on the AC it sounds like it just wants to shut off, but it does not It is like it is not adjusting itself fast enough.
I just do not want to spend $60.00 or $70.00 on something that I do not have to have since I do not have to go through emissions anymore.
Also, thanks Jacob for responding.
Sep 12, 2018 at 12:10 PM
  • 110,246 POSTS
Happy to help.
I have to be honest. What you are describing sounds like a bad idle air control valve (IAC). It is located on the front of the throttle body and its only job is to maintain engine idle speed. What I suggest is to remove it and check to see if there is any issues with carbon. Also, have a helper turn the key on and off to see if the small pintle on the end moves.
Here are the directions for removal and replacement. It is really simple. The picture attached shows its location.
AC Motor Removal
REMOVAL
1. Remove air cleaner assembly.
2. Disconnect the negative battery terminal.
3. Disconnect the Idle Air Control (IAC) motor wiring connector.
4. Remove the Torx head mounting screws (2), and remove the IAC from throttle body.
INSTALLATION
1. Install new IAC motor.
NOTE: If the pintle measures more than 1 in (25 mm), it must be retracted by using the IAC exerciser (Tool # 7558). The battery must be connected for this procedure.
2. Install the Torx head retaining screws, torquing them to 20 in-lbs (2 Nm).
3. Connect the IAC motor electrical connector.
4. Connect the negative battery cable.
5. Install the air cleaner assembly.
_____________________________________________________
Here are specific directions for testing:
IDLE AIR CONTROL (IAC) MOTOR
CAUTION: Proper safety precautions must be taken when testing the Idle Air Control (IAC) motor.
NOTE: To perform a complete test of IAC motor and its circuitry, refer to appropriate Powertrain Diagnostics Chart. To test the IAC motor only, special IAC motor exerciser tool number 7558 may be used.
^ Set the parking brake and block the drive wheels
^ Route all tester cables away from the cooling fans, drive belt, pulleys and exhaust components
^ Provide proper ventilation while operating the engine
^ Always return the engine idle speed to normal before disconnecting the exerciser tool.
PROCEDURE
1. With the ignition OFF, disconnect the IAC motor wire connector at throttle body.
2. Plug the exerciser tool (7558) harness connector into the IAC motor.
3. Connect the red clip of exerciser tool (7558) to battery positive terminal. Connect the black clip to negative battery terminal. The red light on the exerciser tool will be illuminated when the exerciser is properly connected to battery.
4. Start engine.
When the switch is in the HIGH or LOW position, the light on the exerciser tool will flash. This indicates that voltage pulses are being sent to the IAC stepper motor.
5. Move the switch to the HIGH position. The engine speed should increase. Move the switch to the LOW position. The engine speed should decrease.
a. If the engine speed changes while using the exerciser tool, the IAC motor is functioning properly. Disconnect the exerciser tool and connect the IAC stepper motor wire connector to the stepper motor.
b. If the engine speed does not change, turn the ignition OFF and proceed to step 6. Do not disconnect exerciser from the IAC stepper motor.
6. Remove the IAC stepper motor from the throttle body.
CAUTION: When checking IAC motor operation with the motor removed from the throttle body, do not extend the pintle more than 6.35 mm (0.250 in). If the pintle is extended more than this amount, it may separate from the IAC stepper motor. The IAC motor must be replaced if the pintle separates from the motor.
7. With the ignition OFF, cycle the exerciser tool switch between the HIGH and LOW positions. Observe the pintle. The pintle should move in-and-out of the motor.
a. If the pintle does not move, replace the IAC motor. Start the engine and test the replacement motor operation as described in step (5).
b. If the pintle operates properly, check the IAC motor bore in the throttle body bore for blockage and clean as necessary. Install the IAC motor and retest. If blockage is not found, refer to the DRB II scan tool and the appropriate Powertrain Diagnostics Procedures service manual.
___________________________________________________________
Take a look at this link. The first thing it talks about is the IAC and what problems may occur. In general, it discusses idle issues.
https://www.2carpros.com/articles/engine-idles-too-high
Let me know if this helps.
Sep 12, 2018 at 12:40 PM
FORENSICS
  • 112 POSTS
Oh, I completely forgot to add in that I also replaced that too with a new one. Could carbon in the hole cause it to not function properly? If so would I clean it with like a Q-tip?
Sep 12, 2018 at 12:46 PM
FORENSICS
  • 112 POSTS
I also just pulled the new IAC just to make sure it was not faulty and when I switch it to on it does move all the way forward and then backwards a bit, but it only does it for the one time I switch it to on unless I unhook the battery and reconnect.
Sep 12, 2018 at 1:17 PM
  • 110,246 POSTS
Yes, there can be a build up. Also, make sure it is working. You may have a bad or damaged connections. Read through the link that I sent. It discusses possible issues with the IAC system.
Sep 12, 2018 at 1:19 PM
FORENSICS
  • 112 POSTS
I checked the connections, I have also gone over each vacuum line connection and I am pretty sure I have got it all hooked up correctly I have a temporary delete cover on the EGR and the vacuum lines that go to it are plugged.
I mean I can even smell it running rich when I start it I can smell the gas permeating unlike any other vehicle I have smelled and with the air filter off sometimes you can just hear it trying to suck in a ton of air.
After replacing the IAC is it supposed to be like driven around or ran for a certain time to permanently calibrate or something because even though it runs and drives it has been a project truck for me so it has not even touched the road in almost three or four years.
Sep 13, 2018 at 10:15 AM
FORENSICS
  • 112 POSTS
Just wondering, could it be the MAP sensor or would that require it to run rich even after warming up?
Sep 13, 2018 at 10:38 AM
  • 110,246 POSTS
The problem with vehicles which have so many sensors and computers to operate them is one can never tell what the problem is coming from. To answer your question, yes. It could run rich all the time if the computer thinks more air in going into the engine than actually is.
I was thinking about this issue. This vehicle has a coolant temperature sensor that sends a signal to the computer. It tells the computer the coolant's temperature, and from that the computer decides how rich or lean to make the fuel mixture. For example, if the sensor is telling the computer it is 5 degrees F, the fuel mixture will be rich. Check that component. I have attached the component location and directions for testing it.
COOLANT TEMPERATURE SENSOR
Coolant Temperature Sensor Test
NOTE:
To perform a complete test of the Coolant Temperature Sensor and its circuitry, refer to the DRB II diagnostic tester. Also refer to the appropriate DIAGNOSTIC CHARTS. To test the sensor only, refer to the following:
PROCEDURE
1. Turn the ignition key to the OFF position.
2. Disconnect wire connector from coolant temperature sensor.
NOTE: Engines with air conditioning: When removing the connector from sensor, do not pull directly on wiring harness. Fabricate an L shaped hook tool from a coat hanger (approximately eight inches long). Place the hook part of tool under the connector for removal. The connector is snapped onto the sensor. It is not equipped with a lock type tab.
3. Connect one lead of ohmmeter to one terminal of coolant temperature sensor.
4. Connect the other lead of ohmmeter to remaining terminal of coolant temperature sensor.
^ For resistance (in ohms) at given temperatures, See SPECIFICATIONS.
^ Replace sensor if resistance readings are incorrect.
TEMPERATURE RESISTANCE (OHMS)
°C °F MIN MAX
-40 -4O 291,490 381,710
-20 -4 85,850 108,390
-10 14 49,250 61,430
0 32 29,330 35,990
10 50 17,990 21,810
20 68 11,370 13,610
25 77 9,120 10,880
30 86 7,370 8,750
40 104 4,900 5,750
50 122 3,330 3,880
60 14O 2,310 2,670
70 158 1,630 1,870
80 176 1,170 1,340
90 194 860 970
100 212 640 720
110 230 480 540
120 248 370 410
Check how much resistance is in the switch in relationship to the ambient temperature. Let me know the results.
Sep 13, 2018 at 12:09 PM
FORENSICS
  • 112 POSTS
I am not so familiar with well anything on a multi-meter, so I did all of the ohm options and these were the readings I got:
2000k 015
200k 144
20k 14.37
2000 1
200 1
Oh, and here is a picture of the multi-meter:
Sep 13, 2018 at 4:03 PM
FORENSICS
  • 112 POSTS
I have no clue if I did those readings right.
Sep 14, 2018 at 12:13 PM
  • 110,246 POSTS
What was the temperature when tested?
Sep 14, 2018 at 12:14 PM
FORENSICS
  • 112 POSTS
It was cold had not been ran all day outside weather maybe 50 or 60F.
Sep 14, 2018 at 12:36 PM
  • 110,246 POSTS
If your readings are correct, the sensor is bad.
Sep 14, 2018 at 1:52 PM
FORENSICS
  • 112 POSTS
Alright, I will pull the old one and buy a new one and test it out. I will let you know if it works or not.
Sep 14, 2018 at 2:05 PM
  • 55,561 POSTS
Joe is one of our best! Please let us know what happens.
Cheers, Ken
Sep 17, 2018 at 6:13 AM
FORENSICS
  • 112 POSTS
I have successfully swapped the old with the new and now it idles low and calm. Thanks guys.
Sep 30, 2018 at 4:45 AM
  • 110,246 POSTS
Happy to help. Let us know if you have questions in the future.
Sep 30, 2018 at 12:15 PM
