Egr valve
39,000 MILES • 3.4L • 2WD
MSM1951
Just replaced the egr valve with new
Should check engine light go off or does it need to be cleared
Aug 24, 2020 at 10:10 AM
  • 110,251 POSTS
I'm not sure what the code was, but it should eventually go off if the problem has been resolved. The vehicle (EGR System) will need to complete a predesignated drive cycle that can take several miles and start cycles to complete.
You can also clear the code. If the problem still exists, the light will return. Here is a link that explains how to turn it off:
https://www.2carpros.com/articles/check-engine-light-clear-codes
Aug 24, 2020 at 1:35 PM
