EGR valve
167,000 MILES • 2.4L
TONY VIOLANTE
Is 2002, and 2006 EGR vale compatible? I received an EGR valve in the mail and they sent me one for a 2002. Will this work/fit my car? I waited three weeks for this part. Please help me, so i know if it will fit.
Thank you, Tony
Dec 19, 2017 at 3:08 AM
  • 55,766 POSTS
Can you upload pictures of the valves so I can see them?
Dec 20, 2017 at 6:29 AM
TONY VIOLANTE
I just found out today, My 2006 PT CRUISER, don't hAve a EGR valve. Is this possible? Now, I was told it is the Catalylic Comnverter. It ha, N9 poser, drags, and goes erg slow! Getting worse. Very noisey.
Dec 20, 2017 at 8:44 AM
Good morning my name is Roy and I will assist.
It does sound like the cat converter is the issue but you can check it a couple of ways.
You can get a back pressure gauge and install it where the upstream O2 sensor is located and measure the back pressure.
If you dont have a back pressure gauge then unbolt the front pipe from the manifold and drive the car and see what happens
Yes, there are models that do not have EGR valves. the 2006 is one for both the turbo and non turbo models.
Dec 20, 2017 at 7:53 PM
