Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Jimmy
Emission
EGR Valve
Replace/Remove
When warmed up EGR valve sticks open
1995 GMC JIMMY
236,000 MILES • 4.3L • 6 CYL
RICH MITCHELL
MEMBER
1 POST
EGR valve sticks open only when it warms up. I replaced EGR four times and i replaced the PCM and EGR connector. I am at a loss.
Mar 13, 2019 at 8:42 AM
Experienced Mechanic
Good evening,
The reason the valve gets stuck open is from carbon that is in the system and it holds the pindle up and it creates a vacuum leak.
The engine has to be de carboned to stop this from happening. There is no issue with the valve or any other component. It is carbon.
Mar 15, 2019 at 12:32 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
