EGR valve
167,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
PAPAW51
  • 21 POSTS
I removed the EGR valve yesterday, it was stuck open, return spring works, diaphragm is not capable of holding any vacuum and the expected nasty oil soaked carbon buildup is there. Intake manifold port is remarkably clean, exhaust manifold port is dry black soot, much like the tailpipe. I made a plate and gasket to block off the manifold ports. My question is, do I need to get the EGR valve operational for my engine to breath correctly, also is there any danger of building any pressure that would damage oil seals if I continue to run with the manifold ports blocked off? The only vacuum that is operational is PCV valve and vacuum advance. Both from separate sources. CJ MEDEVAC, if you happen to get wind of this, feel free to wax poetic about your assessment of my issue here.
Thanks to any replies in advance.
Mar 14, 2019 at 6:49 AM
Good afternoon.
No, it will not cause any issues. It is there for emissions issues. If you are in a state that has emission testing and yours needs to be tested, then yes, it has to be hooked up and working.
Otherwise you can leave it blocked off.
Mar 14, 2019 at 7:43 AM
PAPAW51
  • 21 POSTS
Thanks asemaster. I appreciate your answer.
Mar 14, 2019 at 7:46 AM
CJ MEDEVAC
  • 11,000 POSTS
Block it off!
One less thing to go wrong.
When you have headers, there is no EGR provision.
Engine works fine!
The Medic
Mar 14, 2019 at 8:46 AM
PAPAW51
  • 21 POSTS
On it! I appreciate the answers. Maybe soon I will have a hard question to answer and challenge you guys a bit. Haha. Carrying on..
Mar 14, 2019 at 8:51 AM
CJ MEDEVAC
  • 11,000 POSTS
Keep us posted!
The Medic
Mar 15, 2019 at 12:23 PM
PAPAW51
  • 21 POSTS
Okay. Will do. My homemade EGR cover plate seems to be working fine. Gasket is holding no exhaust or vacuum leaks around the plate,that I can tell anyway.
Mar 15, 2019 at 11:56 PM
Good. Keep an eye on it for any leaks.
Mar 16, 2019 at 12:02 AM
