EGR tube
190,000 MILES • 3.5L • 6 CYL • AWD • AUTOMATIC
DUSTINMORGAN5617
  • 5 POSTS
I have a bad vacuum leak where the EGR tube goes into the upper intake. there is too much play back and forth when bolted in. Like it is missing something. It is causing the engine to surge in and out. What can i do?
Apr 7, 2016 at 12:31 PM
HMAC300
  • 48,601 POSTS
Remove tube and see if gasket in picture is still there it is a silicone gasket that may be your problem. Also, see if tube bracket is broken as it should not be. See pictures.
Apr 8, 2016 at 12:24 AM
DUSTINMORGAN5617
  • 5 POSTS
Does this black seal go in the hole of the intake? If so how does it stay in there?
Apr 9, 2016 at 11:42 AM
HMAC300
  • 48,601 POSTS
The seal is on there if the bolts should go where small arrows are to hold pipe. If not tight enough and still leaks put the black seal on and tighten bolts.
Apr 10, 2016 at 1:24 AM
DUSTINMORGAN5617
  • 5 POSTS
Now there is no vacuum leak, but it is idling rough. when you put it in gear It smooths out.
Apr 10, 2016 at 8:41 AM
HMAC300
  • 48,601 POSTS
Try cleaning throttle plate on both sides and IAC hole with choke cleaner.
Apr 10, 2016 at 9:32 AM
JOEL MASHACK
A little late to the party, but the reason for the leak is you have the seal backwards. The skirt on the seal must face the other direction in order to seal. If it is backwards as shown in your photo the vacuum will pull the seal inward and leak around it.
Apr 19, 2018 at 7:18 AM
  • 55,766 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site. :)
Cheers, Ken
Apr 22, 2018 at 4:18 AM
JCLEMO
  • 161 POSTS
And I agree Ken a very keen set of eyes and he solved a problem others overlooked just by being alert and paying close attention to detail. Good Job JOEL M. Member JC
Nov 29, 2018 at 9:49 AM
