Engine has been losing acceleration
2008 BMW 320D
160,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
STEVIE WALKER
Came up as an DPF and EGR fault. Mechanic did a DPF treatment and cleaned the EGR valve. DPF fault has cleared, but i`m still losing acceleration at times and diagnostics say its an EGR fault. Any ideas what my next move should be?
Sep 24, 2019 at 1:39 AM
  • 55,433 POSTS
It sounds like the fuel filter is clogged have you had it serviced lately? Also check the air filter as well. We should run the codes as well. Here are two guides to help us:
https://www.2carpros.com/articles/engine-has-low-power-output
and
Sep 25, 2019 at 5:40 AM
STEVIE WALKER
The car is due a service after 500 miles. When i get paid i will get service done and report back if the problem clears after that. And thanks.
Sep 25, 2019 at 7:46 PM
  • 55,433 POSTS
It should, please let me know.
Sep 26, 2019 at 3:22 AM
