EGR problem
113,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
SEAN VINYARD
Have the car listed above v6. Car was recently serviced. Do not believe the vacuum lines were reinstalled correctly. The diagram under the hood is worthless. Where can I find photos or usable diagrams of the vacuum system for my vehicle? What is happening is the car is not starting after it has been driven. The manifold is getting very hot. And on occasion it will stall. Obd test saying there is an issue with EGR.
Mar 16, 2018 at 3:43 AM
Good afternoon.
What is the code that was set?
There are many diagrams depending on calibration code. the code is on the white engine tag under the hood, lower right side of the tag.
Mar 16, 2018 at 5:02 AM
