EGR pressure sensor valve location
18,000,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
N5LED
Where is the EGR pressure sensor valve located at?
Jun 8, 2020 at 11:28 AM
I assume you mean the differential pressure feedback exhaust gas recirc sensor. In other words the DPFE.
I attached the info for it. Let me know if you need something different. Thanks
Jun 8, 2020 at 12:46 PM
N5LED
I guess. My truck doesn't have one because I looked all over it driver side and passenger side and behind the motor.
Jun 11, 2020 at 7:03 AM
Are you located in the USA? If so, it should have one. Can you get a picture of your engine because it should be on the driver side of to the engine. Do you see the EGR valve itself?
Snap a few pictures and we will see if we an find it. Thanks
Jun 12, 2020 at 11:16 AM
