Hi guys. My vehicle seems to have detonation/spark knock while accelerating, also some slight hesitation if I hold it around 60 mph. I suspect the EGR valve so I sprayed some EGR cleaner through the intake and the detonation/rattle stopped for about twenty minutes before returning.
I plugged a scanner in to read the commanded EGR and EGR error values and I got "Commanded EGR - 38% , EGR error -99.2%" at idle.
"Commanded EGR - 5.1%, EGR error +88.3" at 2000 RPM.
Any input as to what these values mean in real terms.
Removing the EGR as soon as I can to clean and I am hoping this is the main issue.
May 20, 2016 at 12:28 AM
