combination flasher - turn signal flasher?
194,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
DURANGO2003STAN
I bought a used 56049114AC combination flasher and I would like to see a schematic of it to know hoe to separate the rapid-flash-needed detection from the turn signal output and add a simple voltage divider resistor circuit to get rid of rapid flash detection. You have a wonderful Exterior Lamps Circuit diagram which shows all the in/outputs. Do you have a schematic for the 56049114AC Combination Flasher?
Mar 1, 2019 at 7:40 AM
  • 110,251 POSTS
here is the turn signal flasher location with the wiring diagrams so you can see how the system works along with a guide to help check the wiring.
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Mar 3, 2019 at 12:51 PM
DURANGO2003STAN
Hi Joe,
thanks for the wiring diagrams I had a pinched wire to the flasher all fixed!@
Mar 4, 2019 at 7:15 AM
