ECU unit replacement?
230,000 MILES
WELD ALGARBYA
Dear sir,
It is very expensive to buy a New ECU, so I took it to an engineer to have a look .and we found two transistors one with a name on top. dale wsr-2and resistance of 0.04 ohms and there is six small transistors or semi-conductors .one is burnt out as you will see in the image.
So please, I need the right codes so I can bring the ECU back to work.
The vehicle listed above has a 3.0 L engine.
Thank you very much!
Feb 11, 2023 at 4:46 AM
WELD ALGARBYA
I tried to upload the photos and could not upload them.
Feb 11, 2023 at 4:50 AM
  • 110,251 POSTS
I'm not sure what you are looking for. If you need a specific part number, that isn't something provided to the technicians. The manufacturers expect the entire part to be replaced. However, I totally understand where you are coming from.
If you are unable to find what is needed, check online for a remanufactured one. They are much less expensive and in most cases, you can just plug them in, and they work.
Feb 11, 2023 at 2:01 PM
WELD ALGARBYA
I am trying to get the part numbers of the six small black transistors and the two black transistors.
Feb 12, 2023 at 2:10 AM
  • 110,251 POSTS
I feel really bad, but I don't have that kind of information. I would contact a place that specializes in ecu repairs.
Here is an example:
https://www.ecudoctors.com/
I have a feeling they would be helpful.
If possible, could you let me know if you find what you need? I'm really interested in knowing.
Feb 12, 2023 at 11:48 AM
