ECU/TCM replacement advice?
1996 MAZDA FRIENDEE
150,000 MILES • 2.5L • 4 CYL • TURBO • 4WD • AUTOMATIC
SLIPMATT
Mazda Bongo Friendee SGL5 / 4WD/AT
Most cold starts the following happens:
• Fans running
• No glow plug light
• No aircon
• Limp mode
Occasionally it will start normally but will overheat.
We suspect the TCM is faulty as per https://www.2carpros.com/questions/possible-ecu however since it does work sometimes, could it be the wiring instead?
Getting a replacement part shipped to Australia is expensive, especially if it is not the root cause.
Thanks.
Feb 12, 2023 at 12:09 PM
  • 55,433 POSTS
Did all of these problems start at once? Also have you run the codes to see what comes up. I would do a CAN scan which can tell you which module is out or if there is a wiring connection problem. The scan is easy to do.
You can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
This way we can confirm the problem before you need to ship any parts.
Feb 13, 2023 at 2:08 AM
