Will a Magnet Marell ECU work in my car?
150,000 MILES • 2.0L • 4 CYL • MANUAL
LEYKB
After going to a car wash the car stopped working. The engine won't start. The mechanic said I need to change the ECU, fuse box with the key. The ECU in my car is Magnet Marell and the one I found is Bosch. Will it be compatible for my car?
Jun 8, 2021 at 5:13 PM
It is hard to know for sure if it will work and that would be a question that we would have to review with the supplier of the part.
However, can you send a link of the part that you are trying to use? If the Bosch part shows that it will fit your vehicle then I would assume it would be just fine.
https://www.2carpros.com/articles/how-to-replace-a-bcm-body-control-module
We do not have a manual on this vehicle as it is not offered here in the USA but I am sure we can figure this out with the info specific to this parts.
Please let us know and we can go from there. Thanks
Jun 10, 2021 at 8:49 AM
