Will a Magnet Marell ECU work in my car?
LEYKB
  • 2002 CITROEN XSARA
  • 2.0L
  • 4 CYL
  • MANUAL
  • 150,000 MILES
After going to a car wash the car stopped working. The engine won't start. The mechanic said I need to change the ECU, fuse box with the key. The ECU in my car is Magnet Marell and the one I found is Bosch. Will it be compatible for my car?
Wednesday, June 9th, 2021 AT 12:13 AM
It is hard to know for sure if it will work and that would be a question that we would have to review with the supplier of the part.
However, can you send a link of the part that you are trying to use? If the Bosch part shows that it will fit your vehicle then I would assume it would be just fine.
https://www.2carpros.com/articles/how-to-replace-a-bcm-body-control-module
We do not have a manual on this vehicle as it is not offered here in the USA but I am sure we can figure this out with the info specific to this parts.
Please let us know and we can go from there. Thanks
Thursday, June 10th, 2021 AT 3:49 PM
