The catalytic converter code turns off sometimes on and off and the misfire code is intermittent and the evap code sometimes turns off. the heater core hose exploded and leaked antifreeze to the left side of the engine. All three the o2 sensor harness purge valve harness and cylinder three wire are near where it leaked. Could the antifreeze have caused the ECU to short causing these codes? I already changed the purge valve, evap pump, hose to purge valve, and vapor canister. And had it smoked tested twice and they can't find a leak. Injector. wires, distributor, and o2 sensor and still get the codes.
Dec 11, 2021 at 3:40 PM
