ECU wiring diagram
17,000 MILES
ROTAVIOUS
  • 7 POSTS
Hey, I’m new to this whole mechanic thing and I’m trying to find a diagram for the wires connected to my ECU. like the fuel pump wire, trunk release, lock and unlock and etc. if anyone knows anything thank you in advance.
Jan 13, 2021 at 1:27 AM
Good evening,
I attached the diagram of the engine control module for you to view.
The wires are labeled for what they control.
Jan 13, 2021 at 9:06 AM
ROTAVIOUS
  • 7 POSTS
Hey thank you so much for the reply. but, still not seeing what I'm looking for. I'm needing the provided wires so I'm able to tap into the and install my kit. I was told to wire through the ECU not sure if that's where I would find these wires or not. if it isn't if you can please guide be that direction I would be highly appreciative.
Trunk release
Unlock
Lock
Fuel Pump
Hand Brake
Parking brake
Horn Wire
Jan 14, 2021 at 3:51 AM
What kit are you trying to install?
You should never tap into anything as it will overload that circuit.
Jan 14, 2021 at 4:17 AM
ROTAVIOUS
  • 7 POSTS
It’s a PKE remote start push to start button.
Jan 14, 2021 at 12:27 PM
Can you take a picture of the instruction sheet for me to see so I can help?
Jan 14, 2021 at 7:20 PM
ROTAVIOUS
  • 7 POSTS
I know everything as far as the wire harness, just lost on the 10 pin.
Jan 14, 2021 at 10:14 PM
ROTAVIOUS
  • 7 POSTS
"ignition harness" sorry.
Jan 14, 2021 at 10:55 PM
What have you hooked up so far?
Jan 14, 2021 at 11:12 PM
ROTAVIOUS
  • 7 POSTS
None so far. I didn't want to start anything until I know exactly where everything is, so I can finish it within a day so I'm not having to call people for rides. because only half of the kit is connected and I'm not able to drive my car.
Jan 15, 2021 at 12:41 AM
ROTAVIOUS
  • 7 POSTS
Just checking in for an update?!
Jan 19, 2021 at 12:44 AM
I attached some diagrams for you to review. I hope this helps with your wiring. Here are the engine wiring diagrams. This is not something we can do here online. It needs to be done in person with someone who can read and understand where to connect the wires for you.
Jan 20, 2021 at 8:54 AM
