Not starting need a ECU connector pinout diagram
100,000 MILES • 4 CYL • 2WD • MANUAL
ALEX GATLIN
  • 47 POSTS
Car no start. Not getting spark or injector pulse. Need ECU pinout please. Thank you.
Feb 20, 2021 at 5:05 AM
ALEX GATLIN
  • 47 POSTS
Hey guys, thanks but got it fixed. Whoever owned by car before tried to fix ignition problem.by swapping PCMs. Caused injector pulse problem Swapped back to OEM PCM, injector pulse solved. Did some diagnostics on ICM and discovered open between +/- CKP wires. Will replace bad CKP. Thank you, miss you guys. Alex.
Feb 20, 2021 at 11:22 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Glad to hear you got the problem solved. Thanks for using 2CarPros and hope you will use our site again in the future when needed.
Feb 21, 2021 at 7:11 AM
Sorry we did not get to you earlier but thanks for updating us. I am attaching the info below in case you need it but sounds like you don't.
Also, in case others need this here is a guide that helps with this issue:
https://youtu.be/dCjmRL3p4Cs
Below you will find this detail. Thanks again and please come back.
Feb 21, 2021 at 7:14 AM
