How to conduct an ECU relearn?
20,000 MILES • 4 CYL • 2WD • AUTOMATIC
KOUBEAR
  • 43 POSTS
Does anyone know how would an ECU would take to relearn things after replacing a car battery and is there a way to confirm it?
Oct 25, 2021 at 6:11 AM
SQM
  • 6,383 POSTS
After the battery is replaced, there are two procedures need to be performed.
1.Perform steering sensor zero-point calibration
2.Memorize steering angle neutral point
I have attached the both of those procedures below.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Oct 25, 2021 at 10:19 AM
KOUBEAR
  • 43 POSTS
Hi, what others procedure do I need to do or relearn? Will I still be able to get dtc code on my obd scanner even though I changed the battery because I did it and it says I got none?
Oct 27, 2021 at 8:10 PM
SQM
  • 6,383 POSTS
According to Toyota those are the two relearns needs to be done after a battery change.
As for the codes, if any issues still exist it will get triggered again and you will be able to read them.
Oct 28, 2021 at 1:51 AM
KOUBEAR
  • 43 POSTS
Okay, thanks. I read it should have cleared all existing code and I didn't use a memory saver or anything. I got the obd on Amazon and it says it was compatible but when I looked it up on their website it wasn't.
Oct 28, 2021 at 10:21 PM
SQM
  • 6,383 POSTS
Curious what type of code reader was it? For just reading the codes, just about any of the OBDII readers will do that task. Unless you want to read live data or other programing function, which will require specific kind.
Oct 28, 2021 at 11:37 PM
KOUBEAR
  • 43 POSTS
It's a Innova 3100rs Fixassist.
Oct 29, 2021 at 4:39 AM
SQM
  • 6,383 POSTS
This is compatible with all the OBDII vehicles (1996 and newer).
So, it should work. I know this one can also do live data as well as airbag and ABS codes.
Oct 29, 2021 at 5:39 AM
KOUBEAR
  • 43 POSTS
I thought so,maybe it's just me.
Oct 29, 2021 at 6:34 AM
SQM
  • 6,383 POSTS
It is possible that the scanner itself has a bad cable or defective.
Oct 29, 2021 at 6:36 AM
KOUBEAR
  • 43 POSTS
It's possible. Maybe.
Oct 29, 2021 at 6:54 AM
KOUBEAR
  • 43 POSTS
Ran my obd scanner and this is what I founded:
Oct 29, 2021 at 7:05 AM
KOUBEAR
  • 43 POSTS
Hey.
Oct 29, 2021 at 1:51 PM
SQM
  • 6,383 POSTS
So those are historical codes. Are you currently having any specific issues?
Inactive code can be stored in the computer but that will not impact the drivability.
Oct 31, 2021 at 5:44 AM
KOUBEAR
  • 43 POSTS
I have no codes when I run my obd2 test, but I know it just doesn't feel the same I know there is an issue.
Nov 1, 2021 at 4:13 AM
SQM
  • 6,383 POSTS
I have attached the reset procedure for the hybrid ECU below. Let me know if you are able to run through those steps.
Nov 2, 2021 at 10:58 AM
KOUBEAR
  • 43 POSTS
Hey, my car is not a hybrid? Will the same process still work? FYI my car is in the auto shop to fix my rear bumper damage.
Nov 5, 2021 at 9:44 AM
SQM
  • 6,383 POSTS
Well, the code showed to be for the Hybrid Camry. And that procedure is for the ECU of the Hybrid system.
Nov 6, 2021 at 1:04 PM
KOUBEAR
  • 43 POSTS
Hmm, that's so weird.
Nov 11, 2021 at 9:55 PM
SQM
  • 6,383 POSTS
So, is the check engine light currently illuminated? If so what are the codes?
Nov 12, 2021 at 12:37 AM
