The truck runs fine. my temperature gauge work until it reaches operation temperature then all gauges peck out.
Nov 3, 2019 at 11:50 PM
BMDOUBLE
✓Experienced Mechanic
The oil pressure sending unit, coolant temperature sensor, and gauges ground through ground G201 at the driver side lower dash behind the cowl panel. I would strongly suggest you check this first because I have had issues with rust forming behind this ground. It will be held on with an 8mm bolt. I've attached a picture of the location.
