Eco idle not working
16,000 MILES • 0.9L • 3 CYL • 2WD • AUTOMATIC
MUHAMMAD91
I am noticing that my Eco idle function in Japanese ALTO (660 cc) is not working. It continuously blinking yellow light of Eco idle off. what should i do now ?
Thanks in advance.
Oct 12, 2018 at 4:08 AM
  • 55,694 POSTS
It sounds like the throttle actuator is having a problem, but to be sure lets run the codes to see what comes up. This guide will show you how but the connection will be different since it is in Japan.
Cheers, Ken
Oct 13, 2018 at 6:42 AM
MUHAMMAD91
Thanks Ken.
Is there any other way to check?
Oct 16, 2018 at 3:36 AM
  • 55,694 POSTS
Not really, its such a new car it might need to go to the dealer for a program update. Either way need to run the codes. Let me know what happens please.
Oct 16, 2018 at 3:42 AM
MUHAMMAD91
Hi Ken,
Hope you are doing well!
I have checked it with scanner, everything was okay, except idling-stop.
It comes with the code of (P1382 (starter control module)).
Mechanic said replace the battery. That is why Eco-idling is not working.
So what should I do now?
Thanks in advance.
Oct 20, 2018 at 5:17 AM
  • 55,694 POSTS
A weak battery can cause issues let's test it first by following this guide.
If okay I would replace the starter module, Let me know how the test turns out.
Oct 22, 2018 at 3:05 AM
MUHAMMAD91
HI Ken,
Thanks for your reply.
I have checked this battery, it works fine on load test.
Waiting for your early reply.
Thanks
Oct 23, 2018 at 3:11 AM
  • 55,694 POSTS
Yep the starter module is next which may need to be initialized by a shop. I would see if you can get a used one first and plug it in to see what happens.
Oct 23, 2018 at 3:34 AM
