ECM/TCM fuse keeps blowing
215,000 MILES • 3.5L • 4 CYL • 2WD • MANUAL
JAMIE LEJEUNE
ECM/TCM keeps blowing to the point can't put a fuse back in.
Feb 21, 2021 at 5:37 AM
Good morning,
I would start by disconnecting the engine control module and see if the fuse still fails when the key is turned on.
If it does, there is a wiring issue between the fuse and the engine control module.
If it clears, then the engine control module is the issue.
Engine Control Module Replacement
Notice:
* Turn the ignition OFF when installing or removing the control module connectors and disconnecting or reconnecting the power to the control module (battery cable, powertrain control module (PCM)/engine control module (ECM)/transaxle control module (TCM) pigtail, control module fuse, jumper cables, etc.) in order to prevent internal control module damage.
* Control module damage may result when the metal case contacts battery voltage. DO NOT contact the control module metal case with battery voltage when servicing a control module, using battery booster cables, or when charging the vehicle battery.
* In order to prevent any possible electrostatic discharge damage to the control module, do no touch the connector pins or the soldered components on the circuit board.
* Remove any debris from around the control module connector surfaces before servicing the control module. Inspect the control module connector gaskets when diagnosing or replacing the control module. Ensure that the gaskets are installed correctly. The gaskets prevent contaminant intrusion into the control module.
* The replacement control module must be programmed.
Important: It is necessary to record the remaining engine oil life. If the replacement module is not programed with the remaining engine oil life, the engine oil life will default to 100 percent. If the replacement module is not programmed with the remaining engine oil life, the engine oil will need to be changed at 5 000 km (3,000 mi) from the last engine oil change.
Removal Procedure
1. Using a scan tool, retrieve the percentage of remaining engine oil. Record the remaining engine oil life.
2. Disconnect the negative battery cable.
3. Disconnect the intake air temperature (IAT) sensor.
4. Loosen the clamp at the air cleaner assembly.
5. Remove the push pin attachment from the outlet resonator/duct assembly to support bracket.
6. Loosen the clamp at the throttle body assembly.
7. Disconnect the positive crankcase ventilation (PCV) fresh air hose at the cam cover.
8. Remove the outlet resonator/duct assembly.
9. Remove the J 1 and J 2 connectors at the engine control module (ECM).
10. Remove the 4 ECM attachment bolts.
Installation Procedure
1. Install the ECM.
Notice: Refer to Fastener Notice.
2. Install the ECM bolts.
Tighten the engine control module bolts to 8 N.m (71 lb in).
3. Connect the J 1 and J 2 ECM electrical connectors.
4. Install the outlet resonator/duct assembly into position.
5. Connect the PCV fresh air vent hose assembly.
6. Tighten the clamp at the throttle body assembly.
7. Position the outlet resonator/duct assembly up with the support bracket and install the push-pin.
8. Tighten the clamp at the air cleaner assembly.
9. Connect the IAT sensor connector.
10. Connect the negative battery cable.
Notice: If a new ECM is being installed, it must be reprogrammed with new software and calibrations. Refer to Service Stall System (SSS) User Guide for reprogramming procedures. The ECM may be damaged if the reprogramming process is interrupted. Make sure the scan tool is connected securely to the DLC and the vehicle battery has sufficient charge.
Important: Ensure the original ECM has the correct VIN and vehicle options.
11. Program the ECM. Refer to Programming and Relearning. See: Vehicle > Programming and Relearning
Important: The new ECM must learn the passlock password from the body control module (BCM). When the ECM reprogram is completed, use the Service Stall System (SSS) to perform the ECM Passlock Relearn Procedure.
12. Perform the Passlock Relearn Procedure using the SSS.
13. Turn the ignition to OFF for 10 seconds.
Feb 21, 2021 at 6:41 PM
