ECM smokes when you try and crank it up. It will turn on battery wise but you pretty much have to floor the gas while turning the ignition all the way after a few minutes. If you're sitting idle like at a light it will shut off. No noticeable wire damage that I can tell. Would I be able to replace this myself with a salvage ECM or what?
Jan 15, 2019 at 2:28 PM
