ecm reprogramming saturn vue
75,000 MILES • 3.5L • 6 CYL • AUTOMATIC
NICKTHEBEST
  • 13 POSTS
I had asked a question about an ecm location for my 2006 Aaturn Vue with a Honda 3.5l engine and it was answered! Now I kneed to know can this be reprogrammed by a mechanic?or does it need to go to the dealer for reprogramming? Thank you
Mar 14, 2016 at 10:37 PM
HMAC300
  • 48,601 POSTS
Any garage that has a professional style scanner can do it.
Mar 14, 2016 at 10:51 PM
SATURNTECH9
  • 30,869 POSTS
I was asked to step in and help out with this one.If they have a tech2 or another pass thru device/scan tool capable of programming gm ecms. Also they would have to have access to gm this software and website to download the calibration files for the ecm. You would have to call around and ask them if they can program gm ecms.or take it a GM dealer to have it done.
Mar 17, 2016 at 11:37 AM
NICKTHEBEST
  • 13 POSTS
Great, thanks for all the help! but what I need to know is if I put in the ecm module myself will the truck run so I can drive it to the dealer to do the programming??
Mar 18, 2016 at 7:19 AM
HMAC300
  • 48,601 POSTS
probably not due to anti theft may no allow it. try it and see but it may not run right
Mar 18, 2016 at 8:18 AM
SATURNTECH9
  • 30,869 POSTS
Is the ecm new or used? You might be able to do a 30 minute pass lock relearn to get it running. Why are you replacing the ecm to begin with?
Mar 18, 2016 at 12:15 PM
