ECM Location
17,000 MILES
TALDAY4476
Is the ECU in the same location on a 2005 Kia Optima 2.7 As the 2006 model the 5 letter of the vin is a D ? and if not where is the ECM located on the 2005 Kia Optima 2.7 5 letter of him is a D ?
Sep 30, 2020 at 4:24 PM
STEVE W.
  • 15,404 POSTS
No it is not. The ECU on the 2005 is located under the hood bolted to the air filter housing while the one on the 2006 is in the interior behind the center of the dash. They are also not interchangeable if that is why you are looking.
Sep 30, 2020 at 4:50 PM
ABESVENOM
I have a 2005 optima and no it's not bolted to the air filter. I am looking for it. Think it may be behind the glove box?
Sep 16, 2022 at 6:21 AM
STEVE W.
  • 15,404 POSTS
Which engine do you have? The 2.7 v-6 is located under the hood on the airbox, the 2.4L 4 cylinder is inside the vehicle in the center of the dash on to of the center tunnel.
Sep 16, 2022 at 12:16 PM
