I am having trouble finding the ECM to replace it.
Aug 10, 2017 at 11:34 PM
STEVE W.
✓Experienced Mechanic
It is behind the trim panel under the dash on the right side of the car in front of the door. Make sure the replacement has the correct ECM part number and the PROM coding is the same. Or swap in the pro from you are current ECM.
