Transmission stopped working. Replaced with remanufactured transmission.
Car sat for about two months waiting for a new transmission.
When I got the car back from the shop there was a check engine light on. ODB2 code was P0453.
Discovered squirrel had chewed through the wire for the EVAP canister vent shut valve connector. Installed new connector pigtail.
Started car and check engine light went off and no codes.
CEL came back on about a minute later. Trouble codes are now P0970, P0966, P0962.
Additionally, the brake indicator light, the ABS and TCS lights now remain on.
The engine was not idling smoothly and when I put my foot on the brake pedal the car stalled but kept running. I turned on my headlights and the car died.
When I tried to do a restart, I heard a fast-clicking noise as though the Bendix gear was not engaging due to a low battery condition. Took the battery out and tested it and it tested fine but charged it overnight anyway.
Next day the car started and ran normal, but all of the lights remain on
It was at that point that I realized that I should go back and check the wiring and noticed that the pigtail connections were reversed.
I changed them to the correct way and reinstalled.
Car started fine so I cleared the codes. Reader said no issues were found but CEL still on as well as other brake related lights stayed on.
Ideas?
I do not have an engine computer reader I just have an ODB2 reader, the FIXD brand.
Final note, after the car died when I turned on the headlights, my ODB2 reader said that it could not connect to the car and said “ Low voltage, is the car on and running “? That only happened one time and it was before I recharged the battery but the battery was showing 12.4 V when I removed it and 12.6 when I reinstalled it.
Ideas?
Jan 6, 2023 at 6:24 AM
