Does the Evap close valve use the same ground from the ECM as the fuel pump? I need engine wiring diagrams
160,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
RD66
  • 61 POSTS
ECM ground distribution. Is there a ground distribution diagram for the ECM? I need engine wiring diagrams
May 2, 2022 at 2:36 PM
  • 55,561 POSTS
No, they do not, the fuel pump ground is under the rear seat while the ECM ground is under the dash on the left side here are the engine wiring diagrams so you can see what I am talking about and how the system works.
This guide can help you check the wiring as well:
May 3, 2022 at 11:13 AM
RD66
  • 61 POSTS
Doesn't the close valve get ground from the ECM?
May 3, 2022 at 12:12 PM
  • 55,561 POSTS
Sorry yes it does, the PCM closes the ground, does the valve have power with the key on? If not check the injector fuse 15 amp. Here is a guide to help:
and the fuse location in the diagrams below. Check out the diagrams (below). Please let us know what happens.
May 4, 2022 at 5:13 AM
RD66
  • 61 POSTS
Yes, it has power with the key on. I'm trying to figure out if it's getting ground.
May 4, 2022 at 12:46 PM
  • 55,561 POSTS
The ground will be connected through the ECM.
May 5, 2022 at 2:46 AM
