Originally, I had my car scanned and received the codes 'P0178-00 Fuel Composition Sensor Circuit Low Frequency' and 'P2119-00 Throttle Closed Position Performance'. I changed the throttle body, cleared the codes and the engine light came off. Unfortunately, once I drove the car and rescanned, the engine light came back on, and the code was 'P0178-00 Fuel Composition Sensor Circuit Low Frequency'.
I also began to notice when I would go to the gas station for fuel, if I would open the tank cover before turning off, it has a rough idle/drag to turn off. Once I'm done getting the fuel and go to start the car there would be a drag/rough start. This has never happened before. I have even noticed a slight change in my fuel efficiency.
Dec 10, 2024 at 10:27 PM
