There are several components that are controlled by the fuse.
I attached a diagram for you to view. Unplug the fuel pump at the pump and see if the fuse still fails. One of those items will be causing the fuse to fail. You need to disconnect one at a time to find the failure.
Image (Click to enlarge)
May 27, 2019 at 5:38 AM
DAVIC7177
MEMBER
ECM-B fuse keeps burning out when attempting to crank engine. Also, taillights not working.
May 27, 2019 at 7:09 AM
(Merged)
✓Experienced Mechanic
Good afternoon,
I just responded to you before to do the checks I recommended to find the fault.
