Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Cadillac
SRX
Engine
Symptoms
Idle Rough
ECM replaced still idling rough
2006 CADILLAC SRX
150,000 MILES • 0.5L • V6 • 4WD • AUTOMATIC
GINGER LYNN DOSS
MEMBER
1 POST
Replaced ECM with new one and had it flashed on vehicle. Still idling rough. Any suggestions on moving forward?
Aug 15, 2018 at 2:50 AM
Experienced Mechanic
Good afternoon.
Why did you replace the PCM?
Is the check engine light on? If it is, do you know the codes?
What work has been done?
https://www.2carpros.com/articles/vibration-noise
Aug 15, 2018 at 6:08 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
