Here is what I have for removal and replacement. The attached pic correlates with the directions.
_________________________________
2006 BMW 325i Sedan (E90) L6-3.0L (N52)
Removing and Installing/Replacing Eccentric Shaft Sensor (N52) [REP-REP-RAE6311N52-1137030 - V.6]
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Variable Valve Timing Actuator Position Sensor Service and Repair Removal and Replacement Removing and Installing/Replacing Eccentric Shaft Sensor (N52) [REP-REP-RAE6311N52-1137030 - V.6]
REMOVING AND INSTALLING/REPLACING ECCENTRIC SHAFT SENSOR (N52) [REP-REP-RAE6311N52-1137030 - V.6]
Repair instruction
Removing and installing/replacing eccentric shaft sensor (N52)
11 37 030 | REP-REP-RAE6311N52-1137030 - V.6
11 37 030 Removing and installing/replacing eccentric shaft sensor (N52)
Necessary preliminary work:
Remove cylinder head cover.
See pic 1
All screws are secured against falling out, loosen the screws (2) only on the cylinder head but do not unscrew.
Screws (2) can fall out.
Risk of damage to timing chain drive.
Unfasten screws (2).
Tightening torque:
11 37 6AZ. Type Thread Tightening specifications Dimension
6AZ
minimum limit position of the eccentric shaft on cylinder head
N52 M6 10 Nm
Remove the sensor (1) upwards.
Note:
Figure without timing chain.
Assemble engine.
If this doesn't help, is the new sensor the same as the old one?
Jun 5, 2020 at 1:58 PM
