Eccentric bolts removal
162,000 MILES • 2.0L • V6 • 2WD • AUTOMATIC
KAYLA SUTTERFIELD
How do you remove an eccentric bolt on a lateral arm or trail arm?
Jun 8, 2019 at 8:16 PM
Good morning,
Did you release the nut on the other side of the bolt?
Do you mean it is frozen in the arm?
Jun 8, 2019 at 8:30 PM
KAYLA SUTTERFIELD
Yes, I release the nut on the other side and the whole bolt seems to be stuck which it I'm thinking it has to be removed a certain way or is stuck in the bushing.
Jun 8, 2019 at 11:01 PM
Yes, that is the issue. It is stuck.
Put the nut back on until the nut is flush with the end of the bolt.
Then take a hammer and hit to see if you can shock it loose and make it move out.
Jun 9, 2019 at 8:27 AM
