How do you remove an eccentric bolt on a lateral arm or trail arm?
Jun 9, 2019 at 3:16 AM
CAR REPAIR CONTRIBUTOR
Good morning,
Did you release the nut on the other side of the bolt?
Do you mean it is frozen in the arm?
Jun 9, 2019 at 3:30 AM
KAYLA SUTTERFIELD
MEMBER
Yes, I release the nut on the other side and the whole bolt seems to be stuck which it I'm thinking it has to be removed a certain way or is stuck in the bushing.
Jun 9, 2019 at 6:01 AM
Yes, that is the issue. It is stuck.
Put the nut back on until the nut is flush with the end of the bolt.
Then take a hammer and hit to see if you can shock it loose and make it move out.
Jun 9, 2019 at 3:27 PM
