1995 Eagle Vision Car stalls for NO REASON!!!!!!!!!!!!!
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONALISA1
1995 Eagle Vision with approximately 150,00 miles. It runs great but sometimes without any warning it just stalls while I'm driving. I can be sailing down the road and then out of nowhere it quits. Once in a while it wont start but then all of a sudden it will start. When the stall happens while driving, if I let it sit a few minutes it starts right up again. This car runs great otherwise. I put in a new fuel filter but two days later the same thing happened.There is no rhyme or reason to it. It runs really smooth so I don't feel its the engine but who knows.
Aug 6, 2008 at 11:31 AM
SERVICE WRITER
  • 9,123 POSTS
When it stalls is when you want to do testing. My first suspicion is a loss of spark, So use a spark tester to confirm this. IF so I would next want to get to the coil and check for any corrosion on any connections, but primarily at the bottom part of the coil that is circled.
https://images.2carpros.com/forum/automotive_pictures/30961_1coil1_1.jpg
In the event you need this:
https://images.2carpros.com/forum/automotive_pictures/30961_1coil_1.jpg
Checking for fuel pressure is also recommened to know that it is only a loss of one, but not both.
Aug 6, 2008 at 12:31 PM
