1995 Eagle Vision Car Stalls and wont restart for a while
1995 EAGLE VISION
174,000 MILES • 6 CYL • FWD • AUTOMATIC
TOMROWE
I have a 95 Vision that sometimes will not start or will stall and not restart. I have to press down the accelerator a bit to get it to start and if I keep it above 1000 rpm it seems to run. Will need to do this for a while before it idles on its own. Where do I start
Dec 1, 2008 at 7:53 AM
Do you have a check engine light ?
Check the coolant temperature sensor and idle air control motor
Dec 1, 2008 at 7:59 AM
TOMROWE
No check engine light. I'll check the other two item out. Thanks for the ideas
Dec 1, 2008 at 9:35 AM
