1995 Eagle Vision #13 fuse
1995 EAGLE VISION
DGHIL
Electrical problem
1995 Eagle Vision V8 Front Wheel Drive
fuse blows, sometimes when you are trying to replace the fuse. Had it working while driving with radio on it blew. Blows weather radio is on or not
Oct 10, 2009 at 12:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuse 13 (10 amp) has almost every electrical component on its circuit. the best thing to do is to turn off ALL electrical systems that you can (radio, lights, do not use door locks etc...) and then replace the fuse. if it still blows than most likely it is the body controller at fault, which is also protected by this fuse.
Oct 20, 2010 at 3:17 PM
