1994 Eagle Vision Spark
1994 EAGLE VISION
ADAM09
Engine Mechanical problem
1994 Eagle Vision 6 cyl Front Wheel Drive Automatic 280xxx miles
I have a 1994 Eagle Vision and it is not turning over apparently it is not getting any spark. I have replaced the spark plugs and all the plugs are in the right spot what could it possibly be. My car is turning over but is not starting
Apr 7, 2009 at 11:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ensure battery is fully charged. Check spark plugs/wires, ignition timing, crank and cam sensors, timing belt, ignition coil resistance, rotor/distributor, ignition control unit and anti-theft system. Post results and I will follow up.
Thanks for using 2CarPros.com!
Apr 7, 2009 at 1:10 PM
