1993 Eagle Talon Water Pump Replacement
To get to it, you need to take off the serpentine belt, move any accessories such as A/C, alternator, ect. out of the way in order to remove the timing belt covers. Then you can take off the timing belt and water pump.
When you replace the timing belt, make sure you align the crankshaft and camshafts correctly and properly tension the timing belt. Let us know.
Suggested Repair
The water pump is behind the timing belt, so remove the serpentine belt, move accessories aside, and remove the timing covers, belt, tensioner, and idler. Also remove the alternator brace and the three water pump bolts; tap gently with a soft-faced hammer if it is stuck. At 93,000 miles, replace the timing belt while it is off, then align the crankshaft and camshafts and tension the belt correctly.
Conversation Summary
The owner of a 1993 Eagle Talon ES with 93,000 miles asked what must be removed to replace the water pump and what to watch for. An expert said the pump is behind the timing belt and recommended replacing the belt at the same time, after moving accessories and removing the covers. The owner then listed Haynes manual steps: remove the covers, belt, tensioner, idler, alternator brace, and three pump bolts, tapping gently if the pump sticks. The expert stressed correct crank and cam alignment and proper belt tension.
